userBXxssu2BZf
Cosmic Ray
No sound from subwoofer and low sound level of HW-Q90R
Hi, I connected my desktop computer to the soundbar. Speakers from the soundbar are working but there is no sound from the subwoofer at all. The volumn of the two rear speakers are also very low. Could you please help me to resolve these issues? The LED at the back of the subwoofer and the two rear  speakers are in blue color so they are connected. Thanks.
7 REPLIES 7
Re: No sound from subwoofer and low sound level of HW-Q90R
Hey, give this link a shot.
userBXxssu2BZf
Cosmic Ray
 Thanks but I have sound from the soundbar. The link does not talk about what to do with no sound from subwoofer.
I would try changing some of the audio driver settings on the computer to ensure that it is pushing out as much information as possible to the soundbar. Depending on the source, certain speakers will sound lower than others.
userjWAb6X8RKd
Check what is the output from your computer, verify setting in software that you are using to play. Probably it is set to stereo
userBXxssu2BZf
Cosmic Ray
Thanks. Under Windows 10's Settings->Sound, ouytput device is Sony TV *00. In Device Properties, Dolby Atmos for Home Theater is selected. Under Input device, Stereo Mix (Realtek(R) Audio) is the only option.
What settings am I supposed to select?
userBXxssu2BZf
Cosmic Ray
I have Dobly Atmos for Home Theater set under Windows 10 but on the soundbar, I set it to Surround. Is this the right way to do?
Have you tried using a format other than Atmos? You're going to have some variation based on the type of sound that you want versus the type and contents of the room. I would try different sound modes on the soundbar and different audio settings on the computer.
