userR0FBj2wkgU
Q70R soundbar - Side Level missing? Virtual sound...what is it?
JUMP TO SOLUTION
I notice when going through the individual sound levels I have:
Center
Front Top
Rear
The manual says I should also have "Side" for a level option as well, but I do not?  Is the manual just wrong, or is my configuration not right?  My sound mode is usually "Adaptive", except when a Atmos source disables it.
Also, in the same level of options, it references "Virtual Speaker", but I cannot find any definition of what this actually is in the manual.  It appears to be off by default.  Anyone know what this actually does?
I am on the latest firmware (1008).
Thanks.
1 SOLUTION
Re: Q70R soundbar - Side Level missing? Virtual sound...what is it?
JUMP TO SOLUTION
Our apologies, the Side adjustment was likely removed via a software update. The virtual settings alter the settings for surround speakers.
6 REPLIES 6
JUMP TO SOLUTION
Can I have your full model code?
userR0FBj2wkgU
JUMP TO SOLUTION
HW-Q70R/ZA
JUMP TO SOLUTION
Thank you for this. You should be able to adjust the Side levels by pressing the Sound Control button to cycle through the different sound modes.
userR0FBj2wkgU
JUMP TO SOLUTION
The current cycle via the sound control button is as follows:
Bass
Treble
Sync
Center
Front Top
Rear
Virtual
No "Side".
JUMP TO SOLUTION
userR0FBj2wkgU
JUMP TO SOLUTION
Thanks, that was the clarity I was looking for and hopefully will help someone else with the same confusion.  Not sure why an update would remove the front L+R...hopefully gets put back in.
