Q950a rear speakers not connecting and Sound Bar is making crackling sound
(Topic created: 07-17-2021 09:40 PM)
userHIg6yMGIMm
Home Theater
Right rear satellite not connecting to Sound Bar. Soundbar started making a loud broken crackling Sound an hour into a movie. Just purchased today. This is so stupid.
user0A5qCu2LoE
Home Theater
I am also not able to get the right rear satellite to pair. The left satellite and sub came paired out of the box. The blue LED is blinking on the speaker, the sound bar is cycling green red blue to pair, but it never does. I moved the speaker to right next to the sound bar. Seems like there's a defect.
SamsungLou
Home Theater
I understand this can be frustrating. Please try reinitializing the sound bar using the following steps from the user guide.
userDYWUXZ0jLr
Home Theater
Have same pairing issue - moved router, initialized multiple times, power cycled, moved speakers, on current firmware
Blinking blue lights on all 3 satellites.
SamsungLarry
Home Theater
Hey, give this link a shot: https://www.samsung.com/latin_en/support/tv-audio-video/how-to-connect-the-rear-speaker-and-subwoofe...
userHIg6yMGIMm
Home Theater
I ended up returning and getting a replacement. Nee one works fine, so I believe I got a faulty one initially
