Replacement remote control sound bar
(Topic created: 06-15-2025 04:32 AM)
FrankyD65
Home Theater
I have a hw-E450c soundbar and i can't connect it to the subwoofer without the correct remote. Should I get a new remote? Where can I get the remote?
Samsung_Moderator
Home Theater
Hi there, Thanks so much for asking about this. For replacement parts and accessories, we recommend reaching out to our parts team directly. You can reach them online at SamsungParts.com or by calling 1-800-627-4368. It's best to have your model number ready to ensure compatibility.
1 Reply
Samsung_Moderator
Home Theater
