Samsung HW-T450 200-Watt 2.1 Channel Sound Bar with Wireless Subwoofer Not connecting
(Topic created: 09-30-2020 12:32 PM)
useryuz3XIZgBV
Home Theater
I have the Samsung HW-T450 200-Watt 2.1 Channel Sound Bar with Wireless Subwoofer. The Subwoofer all of a sudden stopped linking to the soundbar so now no Base. I have tried the Manual connection, resetting and rebooting the soundbar multiple times. When I hold ID Set on the back of the subwoofer, the Blue Link light, and red standby light are lit in Unison, for as long as a I hold the ID set button. The Blue light does not blink to try and connect.
Anyone experienced this or have ideas?
SamsungLarry
Home Theater
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01110023/ If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message or call 1-800-SAMSUNG directly to get started.
wolf43
Home Theater
who do I send my iD
SamsungLarry
Home Theater
useryuz3XIZgBV
Home Theater
The link provided is related to pairing a bluetooth device to the soundbar. The bluetooth is not an issue. The issue is the pairing of the subwoofer to the soundbar
