user0Bnin81k9P
Sound bar HW-F355 does not work
My soundbar does not work. It switches on automatically then in couple of seconds it switches off and again repeat the process. Connect with Bluetooth and it disconnects and switches off. I have disabled autopower and also reset it by pressing the stop button. It is very frustrating. Pls help
2 REPLIES 2
Re: Sound bar HW-F355 does not work
Have you attempted unplugging the soundbar for about 5 minutes and retrying?
userBwhDkPffjq
Hey is it working now? I'm from Singapore and facing the same issue.
