Sound quality SWA-9000S rear speakers with HW-Q70T sound bar.
(Topic created on: 3/2/21 7:06 AM)
BobaMikeTea
Home Theater
OK, so I got the SWA-9000S rear speakers for my HW-Q70T soundbar.  After a couple tries, I got it all linked up, not sure how, it just linked after I power cycled the receiver unit.  I set the rear speakers volume to 6, which is the max level.  It still sounds faint, I checked the cable connections and that wasn't it.  I tried it with regular Samsung plus channels, Hulu shows and the sound was still the same, barely noticeable sound from the rear speakers.
Is this a issue with the Q70T Soundbar and the SWA-9000S speakers? I don't see anyone else really complaining about this except for the Q70T owners.
EddieESuarez
Home Theater
How did you adjust the volume? My speakers crackle and sound cuts off.
BobaMikeTea
Home Theater
It's in the sound settings of the sound bar, I think it's labeled as R for rear speakers, and you turn up the volume from there.  If it's crackling and sound cuts off, I would check the cable connections and possibly contact support for warranty support, you could also have a bad speaker.
