hw-q67CT Sound Bar - Remote does not work out of the box
(Topic created: 12-12-2020 11:19 AM)
user0Q1WAmgkVH
Home Theater
Is there a trick to get the remote to connect?  I've tried using fresh batteries instead of the ones that it came with but I can't find any directions or tips for what to do if it doesn't just work.
user0Q1WAmgkVH
Home Theater
I figured out it, I had the speaker oriented in the incorrect direction.  The diagram on the inside of the box indicating to lay the speaker down flat.  Once I did that, the remote worked just fine.
SamsungCaleb
Home Theater
I'm sorry to hear that, do you by chance have this connected to a Samsung TV using an HDMI cable?
user0Q1WAmgkVH
Home Theater
SamsungCaleb
Home Theater
That's great to hear!
