6.3 Range light not working
(Topic created on: 4/5/21 3:52 PM)
userUY1lMOPKdH
Kitchen and Family Hub
We just recently purchased the 6.3 convention range and had it installed. The oven light does not turn on shortly after installation. We had the oven replaced with the same model. We verified the light turned on at installation and then wouldn’t turn back on after the initial clean run. Same model oven, replaced and same issue. When you push the LCD display to turn on the oven light it will beep but will not turn on.
