Air sous vide bags for 9900 range
(Topic created: 2 weeks ago)
Fernst313
Kitchen and Family Hub
I recently purchased the NSI6DG 9900 SR range. It’s the top of the line induction range in this lineup. One of the reasons I purchase this one was for the air sous vide capabilities.
I also purchased a set of reusable sous vide bags that claimed to be good for air sous vide, but when I received them, the directions said they can’t be used for air sous vide, only in water.
Does anyone else have this range, or another that does the air sous vide?  Have you found a set of reusable bags that can be used for air sous vide?
Thank you.
realaud
Honored Contributor
Is there no recommendation for bags in the user manual? Normally appliances that require a specialized item have a recommendation.  If not, you might try calling Samsung and seeing if they have a recommendation.
Fernst313
Good call.
I have not read all the way through the manual. I will definitely check that.
Thank you.
