Highlighted
Cannot reset refrigerator water filter indicator light.
JUMP TO SOLUTION
When the water filter indicator light turned red, it was easy to replace the water filter with a new Samsung filter.  However, after pressing the area on the control panel for 3 seconds, the water filter indicator light won't reset and is still red.  What should I do?
Samsung refrigerator model RF24R7201SR/AA
1 SOLUTION
Highlighted
Re: Cannot reset refrigerator water filter indicator light.
JUMP TO SOLUTION
Try pressing the Door Alarm button for 3 seconds to see if the controls are locked.
11 REPLIES 11
Highlighted
JUMP TO SOLUTION
You will need to press and hold the ICE Maker button for 3 seconds. This will reset the filter indicator.
Highlighted
JUMP TO SOLUTION
Thank you for your quick reply.  The water filter indicator light turned off after I pressed the ice maker button.  But, now the ice maker is turned off and pressing the ice maker button again doesn't turn on the ice maker.  ???
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
This solution did not work for my Samsung model RF23J9011SG/AA. Any other suggestions?
Highlighted
JUMP TO SOLUTION
Is your refrigerator light blinking? Or is the ice maker not working? To reset the water filter light you will need to Touch the “Crushed/Hold 3 sec for Filter Reset”
button ( (Filter Reset) ) for about 3 seconds to reset the water filter. The color of the indicator changes from red to off.
Highlighted
JUMP TO SOLUTION
I tried for 30 mins to do this and the manual did not help. I searched the web and FINALLY this post helped me. My wife was like "really" and I said , "Come on"
I tried all suggestions! This was the ticket, and so simple
thank you SamsungLou!!!!
Highlighted
JUMP TO SOLUTION
Worked for me. Thanks a lot for posting this. Spent quite a bit of time trying to figure it out  until I ran into this post.
Highlighted
JUMP TO SOLUTION
You are most welcome.
Highlighted
JUMP TO SOLUTION
This solution worked for me, and its insane that the fridge is built this way.
1st) it should automatically reset when a new filter is inserted
2nd) since it doesn't auto reset, why in heck would i EVER want to disable the button to reset the filter?
Hopefully samsung will see this comment and fix it in the future
