DW80B7070US/AA Door will not open to level position
(Topic created: 2 weeks ago)
ChipCarter
Kitchen and Family Hub
Newly installed and the door will not open fully, causing bottom rack to roll back into dishwasher.  Help please.
Samsung_Moderator
Hello! Thank you for raching out! It would be recommend to reach out to the installers to get them to look at this as this will be a installation issue. If they are unable to fix this the next option would be service. Depening on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
1 Reply
Samsung_Moderator
