user1IbayrlDx5
DW80H9930us won't power on
Had an LC alarm.  Fixed the issue and powerd the washer off.  Restored power after 15 min and the washer won't turn on anymore.  I verified the voltage is correct. No response from the touch panel (it worked fine prior to the LC alarm).  Any ideas?  Thanks!
1 REPLY 1
Re: DW80H9930us won't power on
We are sorry to hear about this. Please send the serial number to this PM Link, and we will look in to this.
