Highlighted
Dishwasher DW80R2031US/AA - Clean light always stays on
For some reason, my dishwasher (model DW80R2031US/AA)'s Clean light always stays on. No other lights are blinking or anything, it's jsut the Clean light is stuck to on. I tried disconnecting power for 15 minutes to reset or turning it off and on but to no avail. Everytime when I power on the dishwasher, the clean light just pops on and I am not sure if the light is broken or something. I did a quick search online, and it seems that no one else had this problem before.
1 REPLY 1
Highlighted
Re: Dishwasher DW80R2031US/AA - Clean light always stays on
Have you tried to clean the drain hose? Check to see if any bends or kinks? I recommend running the self clean cycle again to see if it turns off.
