Dishwasher Touch/Control Panel Not Working Correctly
Model: DW80K5050UG/AA 03
S/N: <HIDDEN>
The touch/control panel seems to be malfunctioning.  There are times it doesn't respond to any inputs, and other times it turns on by itself.  I've tried all the troubleshooting methods and nothing works (the panel is clean, the breaker is fine, it's not on a switched outlet).
1 REPLY 1
Re: Dishwasher Touch/Control Panel Not Working Correctly
This is something that would require a service technician.  Could you send me a private message so that I can get some additional info from you?  http://bit.ly/2ihPL97
