Dishwasher not working properly. Model DW80F800UWS/AC
(Topic created on: 1/3/21 10:02 AM)
useroABnBWEey6
Kitchen and Family Hub
I have a dishwasher that isn't working properly.  Model DW80F800UWS/AC. It fills with water and then drains right away and drains all water with no problem, will do this for a bit and then flash 5E. If i disconnect power and then turn it back on the dishwasher will do a complete wash cycle with no issues. After the final cycle sometimes it won't drain all water out and then flash 5E. I have checked the drain line and its clear and nothing stuck in drain or hose. The check valve is also good. if it was the drain pump why would it drain all the water a a few times and then not the next? Looking for any help?
thanks
1 Reply
SamsungAl
This forum is for the support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry  Thanks!
