Re: Stormwash Dishwasher ( dw80k7050ug) will not power on
JUMP TO SOLUTION
Is Samsung not accepting any responsibility for what is clearly a manufacturer's defect, with now 29 pages of complaints about this?
JUMP TO SOLUTION
That is something that would require service.  If you would like to move forward with that process, feel free to send me a private message.  http://bit.ly/2ihPL97
JUMP TO SOLUTION
I have the same issue.  Is Samsung standing behind this product for a known flaw?
JUMP TO SOLUTION
@usermUhd2TCJeP   If you would please send your model and serial numbers to this PM Link, I will be happy to look in to this for you.
JUMP TO SOLUTION
Mine just did this.. 2 months old, it has power but control is unresponsive
JUMP TO SOLUTION
I guess I got lucky since my control panel lasted 2.5 years before crapping out. Anyone have the part # so I can replace?
JUMP TO SOLUTION
i have a similar issue , whats the Part #.  WHats the estimate to get the service dept to fix it?
JUMP TO SOLUTION
Following. Same issue with my dishwasher. Control panel will not power up. Seems to be an ongoing issue with Samsung. What are the fixes, as to have to replace a control board after 2 years is crazy.
JUMP TO SOLUTION
I am having the same problem. I installed unit in mid-2017, so I got three years of service. Comments now on 30th page, so I am not alone. I run mine about once per week, so how can this happen? I had a control panel problem with a Kenmore once, after six years, so I know that this could cost hundreds. Has the company decided to fix these at no cost?
JUMP TO SOLUTION
30 pages of posts and each time Samsung's response is "looks like it needs servicing", out of pocket cost of course. Samsung dishwshers are complete garbage, stick to Bosch if you want top of the line, or Maytag and Whirlpool for something cheaper. My frigidaire worked 10 years witout issues and then I sold it for quite a bit when I moved. Not even 4 year mark this piece of trash Samsung has died.
