07-24-2019 04:34 PM
First time using this, so hoping I'm doing it right. I also have a new Dw80k5050us I bought from a Sears Outlet, & just installed. Use my old dishwasher, turn off breaker, disconnected the old dishwasher & connected this one. Turned on breaker, nothing.. Disconnect, checked everything & reconnected & still nothing... Help would be Awesome
07-24-2019 05:21 PM
You will need to make sure that there is voltage to the connections to the dishwasher. If the connections check out, a technician would need to diagnose the problem.
12-19-2019 03:40 PM
Hi. I am currently having the same issue with my 2 year old Samsung dw80k5050us dishwasher. It stopped mid cycle, water has not drained. There are no lights illuminated on the control panel. I have turned breaker for hour, breaker on now and still no power. Can you help please? Thank you!
12-19-2019 05:44 PM
@user22iqzhfjWr We are sorry to hear about this. Please send the serial number to this PM Link.
08-22-2019 10:09 AM
What was the solution? I am in the same situation, well, not mid cycle, so no water in it, but won’t power on. Connections are good, breaker is good. Was this solved for you?
08-22-2019 11:03 AM
This would require service.
09-20-2019 06:01 PM
I am having the same problem.
This is driving me crazy. My husband is in the military and he is gone all the time. Leaving this problem to me.
Please help
Rhonda
08-23-2019 11:12 AM
Would you like us to set that up for you?
09-17-2019 09:24 PM
@userLYRMGXdZZu What was the resolution? I'm having a similar issue.
09-20-2019 06:04 PM
Try unplugging and plugging it back in it should reset itself. If that new you should have a two year warranty at least. Check for rodents, the breaker and the power level. Double check vuse panel n unplug anything that takes alot of power when trying to restart.
