Highlighted
DW80K7050UG no power
JUMP TO SOLUTION
I have a dishwasher purchased less than a year ago and used about 6 times (the unit is in a vacation home) that will not power on. After reading the comments in this forum I am concerned. Even if the power disconnect resets the unit this is just not an acceptable solution for an appliance this expensive. Samsung have you found a solution yet?
Highlighted
Re: DW80K7050UG no power
JUMP TO SOLUTION
Have you made sure that the circuit breaker wasn't tripped or that the outlet the dishwasher is plugged into is damaged? Was there a power outage in the area?
Highlighted
JUMP TO SOLUTION
The power has been verified at the connection to the dishwasher so power to the unit is definitely not the problem. I have tried the power off reset suggested and it doesn't resolve the problem.
Highlighted
JUMP TO SOLUTION
Let me look into this further for you. Could you send me a private message of the serial number?
Highlighted
Dishwasher DW80R5061 brand new will not power on
JUMP TO SOLUTION
Just bought the  DW80R5061. Removed old working dishwasher and set up this one but no power.
Highlighted
Re: Dishwasher DW80R5061 brand new will not power on
JUMP TO SOLUTION
Hello there, when was the unit purchased? Was it professional installed?
Highlighted
DW80K5050US No Power
JUMP TO SOLUTION
13 month dishwasher, will not turn on.  Finished a load, refilled it and turned it back on a few hours later, and it is now dead.  Confirmed that it is not a breaker issue and there is power to the dishwasher.
Highlighted
Re: DW80K5050US No Power
JUMP TO SOLUTION
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
Highlighted
Samsungdishwasher DW80K5050UB/ Does not power on
JUMP TO SOLUTION
I Have a samsung dishwasher DW80K5050UB that is a year and a half old. Just yesterday the touch panel will not power on. i have cut power using the breaker and let sit for over an hour with no avail. my garabage disposal runs on the same circuit and has no issues. i see many posts of this same issue but didnt notice any resoulution or fix for this issue. Its an expensive dishwasher that should last longer than 1.5 years. Maybe i should have listened to my Wife, but i am Samsung connected with so many other products. Can someone help please!
Highlighted
Re: Samsungdishwasher DW80K5050UB/ Does not power on
JUMP TO SOLUTION
I definitely understand your frustration. Let me know if the link below was helpful:
http://www.samsung.com/us/support/troubleshooting/TSG01001914/
