Re: dishwasher dw80k7050us will not power on
JUMP TO SOLUTION
Are you still needing assistance?
JUMP TO SOLUTION
Yes I do still need assistance.  It does not trip the breaker. I have been unplugging the power cord from outlet every time to turn it on.
Honored Contributor
JUMP TO SOLUTION
And have you tried the steps listed here: http://www.samsung.com/us/support/troubleshooting/TSG01001914/
JUMP TO SOLUTION
Yes I have. Still no response.
Honored Contributor
JUMP TO SOLUTION
Thanks for confirming, honestly the next step would be repairs. Mind shooting me a message here with your serial number?
JUMP TO SOLUTION
My 1 1/2 year old dishwasher is dead is not powering up / this seems like a common problem - is there a recall on this? S/N is B03SG8DJ700304T
JUMP TO SOLUTION
@user8vhiYcF8AE; There are no recalls for this model. However, we would be happy to look into this concern for you. Please send us a private message to the link
JUMP TO SOLUTION
It seems like this isn't a new problem. There are posts from 4 years ago to 2019.
Someone has had to figure this out by now.
No one got an answer from Samsung? Or has anyone had a repair man come and tell them what the problem is?
Mine started doing this about a month ago or so. One day it wouldn't turn on. So I checked the breakers. They were fine. I unplugged the dishwasher and plugged it back in. And then it worked. But then a few days later it happened again. And then again and now every time I need to run the dishwasher, I have to unplug and plug it back in anywhere from 1 time to 10 times. Sometimes it works after unplugging it for a few seconds and others it takes minutes or even hours when I give up after a few tries and come back later to try again....
It's very frustrating... Please help, anyone that got an answer or a fix? Even if my problem won't be able to be fixed the same way, what are the options besides the few simple, limited troubleshooting steps Samsung suggests before giving up and calling a service man.
I would like a chance to fix it myself first. Or at least have an idea what to expect..
Thank you for any help you can give
Dishwasher won’t turn on
JUMP TO SOLUTION
My dishwasher won't turn in.  Worked fine one day, then the next wash nothing....zero power. Have tried the circuit breakers.  Any help would be appreciated!!
Re: Dishwasher won’t turn on
JUMP TO SOLUTION
Our sincerest apologies for the frustration and inconvenience this has caused. Please feel free to send us a private message with your full model code and serial number so that we can look into this for you.
