12-27-2019 05:55 PM - edited 12-27-2019 07:49 PM
Make sure to unplug from power before doing any of this.. I had the same problem and since I had nothing to lose I took a chance and removed the top control panel. I discovered water in the circuit board.. After fully removing the panel and letting it dry out it started working again. I'm taking extra steps of canned air to remove any water hidden behind the plastic covering the majority of the board.
12-22-2019 06:36 AM
We bought it about 18 months back. The touch control started giving us hard time few months back and now is does not at all power on. We spent about an hour fiddling with the circuit breaker and touch controls this morning and finally it came on, but it is very frustrating. Our old mechanical system was 15 years old and we replaced the working one with this junk.
We need to have it fixed by Samsung. It must be a desing defect for the control panel to stop working in 18 months.
I tried to add this message to the existing chain, but the forum would not let me add it, hence I had to create a new one.
12-26-2019 04:44 PM
It seems to be a design defect as the location of the connectors and electronics in the control panel are direct in path of the steam coming out during the drying process, it is only a matter of time, usually 1-2 years, and the part fails and by that time one is out of warranty too. A very celverly designed process to mint money with the replacement parts sales.
It is a classic case for a class action law- suit.
12-05-2019 05:03 AM
3rd time this has happened, dishwasher is right around 1 year old.
1st & 2nd times I reset the breaker and it worked 3rd time was not the charm.
12-05-2019 02:33 PM
@userAyWDmMZcg1 I am sorry to hear about your concern! Will you please send a private message with the model code and serial number so I may see what options are available? http://bit.ly/2XERsky
10-28-2019 05:59 AM
Dishwasher was working fine last night. This morning woke up to a beeping sound. Checked for troubleshoot options online which suggested to turn off the unit by turning off the breaker. After doing that, unit came back on and the beeping was gone. The light indicator is on. However, none of the other buttons are working so cannot power on the unit.
Model is dw80k5050us
Seems like this is a common issue with this dishwasher. How can I fix it?
10-28-2019 07:08 AM
Do you have an error code? Give this a shot: http://www.samsung.com/us/support/troubleshooting/TSG01001914/
11-10-2019 11:49 AM
My Samsung dishwasher model DW80K5050US is not getting power. It worked two days ago but now it is not turning on. Any help would be much appreciated.
12-27-2019 04:52 PM
I had the same issue. Took the panel off (easy to do 6 screws or so) to find it had water in the circuit board. Another post had this issue and their connection to the panel was corroded. If you're fortunate and catch it before that, I left the panel off for a few days and canned air dried it and that fixed the issue. Also adding a liquid rubber gasket to hopefully prevent this issue.
10-28-2019 05:39 PM
I have power going to the dishwasher and its live.
It worked last week I went to do a load and I cant get the powe on.
Is there a fuse somewhere?
