Door flap on RF4287HA hangs too low
(Topic created on: 1/30/21 11:02 PM)
userRYnFm39pDb
Kitchen and Family Hub
Occasionally, the flap on the french door of my RF4287HA hangs too low.  As such, the flap won't catch on the track at the top, and it won't open like it's supposed to when I close the door.  I can lift the flap to prevent this, but it can slide down again later.  Interestingly, this was a problem about a year ago, and then it seemed to go away on its own.  Now it's a problem again.
I was hoping that there would be an obvious screw that I could tighten, or something similar, but it doesn't seem as if user serviceabiliy was a priority with this design; I can't see any simple fix that I can do on my own.
So, what's the solution here?  Is that actually a way for me to solve this problem, or do I need to have someone repair this?
Thanks in advance!
1 Reply
Photographer
I'm just spit balling here. But, if there is not an adjustment on the back side of the door. you may need to put a spacer on the bottom of the door.
