- Mute
- Email to a Friend
‎04-27-2022 08:05 AM in
Kitchen and Family HubHad a pizza in oven yesterday afternoon. Noticed a bunch of clicking and popping sounds. Looked over and the entire top control panel had flames and fire coming out of the back top of the oven where the control panel is. Thankfully we have a fire extinguisher and were also able to disable the breaker and disable the power. Pulled the oven and stove away from the wall and took back panel off. The entire inside of the control panel is burnt and black. If I had not been home and right here to catch it, I'm certain our house would have gone up in flames. After doing some research, I have found this to be an issue all over the internet. Tons and tons of people reporting this issue and it appears that the posts get deleted and Samsung is no help. Warranty or not, any product I purchase should never catch fire. I would like to get some help on this. I have called with little to no help. I have my receipt of purchase, pictures of this damage, and I would like this to be resolved. We own a kitchen full of Samsung appliances and if I don't get the support this deserves, I will never purchase another Samsung product and I will be sure and tell everyone I know.
Thanks,
Solved! Go to Solution.
- Mute
- Email to a Friend
‎04-27-2022 01:22 PM in
Kitchen and Family HubHello! So that we may be able to further assist you can you please send us a private message?
- Mute
- Email to a Friend
‎04-27-2022 09:58 AM in
Kitchen and Family HubHello! I completely understand your frustrations with the range panel catching on fire, I'll be more than delighted to assist you with this issue. Is there any in the home that's damaged besides the range? Also, can you send me a private with your serial number as well? http://bit.ly/2tCGnGK
- Mute
- Email to a Friend
‎04-27-2022
10:48 AM
(Last edited
‎04-27-2022
01:21 PM
by
SamsungCaleb
) in
Serial # for the Range is NE59J7630SS
I have original paperwork with receipts from when we purchased.
Purchase Date: 11/07/15
Purchase Location:
Occurrence Date: 04/26/22
- Mute
- Email to a Friend
- Mute
- Email to a Friend
‎04-27-2022 01:29 PM in
Kitchen and Family HubI have sent a couple of private messages. Not sure what else to do?
