useruuhxcBSw4e
Evaporator Fan freezing RF30HBEDBSR Refrigerator
evaporator fan is continually freezing up approximately every 2 weeks, added new insulation on cover seal since we had read that could be the issue but iced again 2 weeks after that was added. I’ve spoken with Samsung who was zero help and it seems most appliance repair companies do not want to deal with Samsung appliances. If anyone has any idea what this could be I would appreciate any input.
1 REPLY 1
userbCyNvIPFnb
Re: Evaporator Fan freezing RF30HBEDBSR Refrigerator
I had the same problem twice, and just defrosted it. The third time it happened I found a video that said to replace the temperature sensor with the same but with longer wires, then relocate it from the right side tube to the left angled tube. It worked!
https://youtu.be/R_kbnddADDU
Samsung Fridge Freezer RSH1, fridge defrost sensor modification kit. To cure the icing up problems on the left top vents of the fridge back panel the defrost sensor has been modified. Its not just a new sensor but a couple of linked changes that in total alter the defrost temperature and the ...
