Re: FRIDGE NOT COOLING
JUMP TO SOLUTION
Please follow up with us as soon as you can.
JUMP TO SOLUTION
We can look into that.  Could you send a private message with your serial number?  http://bit.ly/2ihPL97
JUMP TO SOLUTION
Please get that to us as soon as you can.
capescuba
JUMP TO SOLUTION
I did reply and predictably you said I just need to get it serviced. No offer to take care of this as it seems like a widespread issue Smiley Sad
userg2dtOvTLgL
JUMP TO SOLUTION
Whirlpool makes a nice refigerator and its made in th USA
userZAW1iYsyCn
JUMP TO SOLUTION
I will NEVER buy Samsung again. I will take a look at the Whirlpool--thx
capescuba
JUMP TO SOLUTION
I had a local technician try to repair my cooling issue. He spent > 17 hours to get it working. Put in a new compressor, flushed the lines with acid etc. But he did eventually get it working! ..... For 1 week, then it stopped again over the weekend.
Time to throw this thing out.
I am amazed there has not been more done by Samsung to address this. We are mostly all capable of checking the warranty on here, and that seems to be all the support can offer us, plus the $200 technician call out to verify it's not working.  Verry dissapointing.
Nebula
JUMP TO SOLUTION
@capescuba
If you would provide me with the service order number I will gladly look into this for you.
usercWEa03gDir
JUMP TO SOLUTION
I have had this Samsung Refrigerator Model RF4287HARS since 2011 and the first year was great. So I gave away my old side by side Whirlpool. Big MISTAKE! wish I had it now. I didn't realize there were so many issues with these computer circuitry models, I just wanted a beautiful model that kept food well and worked great for at least 10 years like all the rest. now, it is the refrigerator compartment not cooling properly. I called the repair service and they told me they no longer work on Samsung because of too many issues. what a nightmare, never again.
userKu2cTm6R6K
JUMP TO SOLUTION
i am having similar issues. Here when you call them, they talk to you sweetly and how they care. I was told a technician team will call me and schdule an appointment. No one called for 15 days. So I called a local tech. They to charged me $90 for diagnosis and told me it iwll work. Nothing worked and now they are saying there is a control board problem and they have to get the part form Sansung. apparently the part is on back order. I cannot believe that a product that sells in large quantities cannot be supported quickly.
suresh
