Refrigerator family hub touchscreen unresponsive/display doesn't work
(Topic created: 11-20-2018 05:45 PM)
userop64rKJLlo
Kitchen and Family Hub
My family hub touchscreen does not respond to touch since yesterday , I can’t unlock the screen. I turned off the screen and turned it back but I can’t unlock the screen. I unplugged the fridge and it didn’t work either.
JUMP TO SOLUTION
userSs6HhwrmXh
Is there a video tutorial that shows how to do this?
Not applicable
The display reset button is located at the top of the right side door. There are more details in your user guide.
userDgTaEdiBsL
Thats not working for me, tried it time and time again. The screen for me, I tap on one part of the screen and it reacts on the complete opposite side. The red switch doesnt do anything. I cant use the screen at all. It lights up, but the touch is uncalibrated and presses whatever it wants. How do i fix this?
userYSZezChoTl
Did they help you? Mine is doing the same thing. I turned the switch off and on and still it does not work .
user7vaUWkPwch
It didn't solve for my fridge. What is the service call number?
Not applicable
@userrgBq7KgdJn
@user7vaUWkPwch
The next step would be to have the unit serviced. You can call into 1-800-SAMSUNG or you can reach out to the Moderators with your full model code and serial number: Link
tlc2tlw
I have tried that several times a day for a couple weeks now and it still doesn’t work.
userOPR1JLlW4T
What if the red button is not resetting the screen still unresponsive?
MsBri1
Neutron Star
Have you tried to power cycle the unit by unplugging it or turning it off at the breaker?
userkcOZHLybJp
It doesn't work, please, do something
