userQ62yDd8cJq
Fan makes hum/buzz/rattle noise from RF28HMEDBSR.
JUMP TO SOLUTION
Our fridge started making a loud fan buzz. It sounds like it's coming from the upper rear center on the inside of the fridge. It only does it when the doors are closed and you can hear it winding down when you open the door. When you close the doors, it winds up to full speed again. We've had this fridge since March 2015. Any ideas?
1 SOLUTION
Honored Contributor
Re: Fan makes hum/buzz/rattle noise from RF28HMEDBSR.
JUMP TO SOLUTION
Thanks for confirming, if this is the case then service repairs would be recommended. Mind shooting me a message here with the serial number for the fridge: http://bit.ly/2igAXKH
374 REPLIES 374
JUMP TO SOLUTION
Do you see any build up of ice in the back by any chance?
user6OTKQsqiCj
JUMP TO SOLUTION
Mine is doing the same thing, and yes, there is ice build up. In December it did the same thing. How can I prevent this from happening? I currently have our rrefrigerator's thermostat at 40 degrees, and there is not an excessive opening and closing throughout the day.
Please advise. Thanks!
Honored Contributor
JUMP TO SOLUTION
user6OTKQsqiCj do you have the same model, RF28HMEDBSR?
user6OTKQsqiCj
JUMP TO SOLUTION
Our Model Number is: RF18HFENBSR
Honored Contributor
JUMP TO SOLUTION
Thanks, just to confirm does the noise(s) happen even with the ice maker turned off?
user6OTKQsqiCj
JUMP TO SOLUTION
It does. Our ice maker is currently off. We do have frost build up on the back wall. When we open the doors the fan stops and it seems to be the fan that is making the noise.
Honored Contributor
JUMP TO SOLUTION
user3gfqYKSEkf
JUMP TO SOLUTION
We have had this problem for a while now. We defrosted the fridge and we thought the problem was solved. Two weeks later, it's back and louder than ever. All of the licensed repair people want at least $100 just to come out. Is there a way to prevent this problem (ice buildup around the fan) from happening, or is this just a design flaw in Samsung fridges?
Nightrdr
JUMP TO SOLUTION
  I have a Samsung RF263BEAEWW with same issue as all the other posts.  I am reaslly bothered that this is such a common issue and Samsung just ignores it.
  My issue started with the ice maker freezing/ice build up.  Defrost, then 3-4 weeks later frozen with ice build up again.  My unit is suppose to have the "update", but all that seems to be is some styrofoam (maybe that is why I can get 3-4 weeks vs the common 2).
  After going thru that cycle for over 1 year, the ice maker stopped working. Estimated >$600 to fix = hmm $1 store ice trays.  About month later (as in now) the fan noise was building.  Searched and found out I now needed to defrost behind the back cover on the inside. Really? What a joy.
 I bought this unit after looking at ConsumerReports and noticing it is a "Recommended" unit.  Semms they would have mentioned the issue (a simple search would have told them), but nothing I have seen so far.  At some point this may become a class action of some kind.  Till then, I will defrost as needed, and save for a replacement.
  I am only one person, but I tell everyone not to buy a Samsung fridge.  Actually I was going to buy a glasstop stove and need a new dryer, but think I will pass on Samsung.
