Re: Fan makes hum/buzz/rattle noise from RF28HMEDBSR.
JUMP TO SOLUTION
What was the final outcome? Did you get another fridge?
JUMP TO SOLUTION
I have the exact same problem. Bought the fridge at the end of 2015 and started to have this issue from about middle of 2017. The model number is RF28HDEDBSR/AA.
Anyone got a solution for this problem?
Want to post a photo here, but don't know how.
JUMP TO SOLUTION
I have posted the solution, please see my previous posts
JUMP TO SOLUTION
Thanks a lot for your quick response!
In the photo you shown in the link https://photos.app.goo.gl/Sqq4r4NANJNmH5896, from left to right, there are three brown copper lines, to which line did you move your sensor?
Again, thank you for the help and have a great new year free of all these kinds of troubles!
JUMP TO SOLUTION
https://photos.app.goo.gl/7rdqzbjywXVh23sB9
Far left, as low as possible
JUMP TO SOLUTION
Thank you very much!
JUMP TO SOLUTION
Don't forget to check your codes in case you have a failed sensor, fan, or heater !!!
JUMP TO SOLUTION
ok, I'm doing it right now.
Thanks !!
JUMP TO SOLUTION
I have the same problem and a buildup of ice a small build up what does that mean
JUMP TO SOLUTION
I have the same problem. Model RF260BEAESR/AA. Did you ever figure what the problem was? Did you get it fixed? I do not have ice build up.
