Highlighted
Re: Fan makes hum/buzz/rattle noise from RF28HMEDBSR.
JUMP TO SOLUTION
We have started having the same issue with the same model. We bought ours in February of 2016. We’ve already given up on the ice maker.
Highlighted
JUMP TO SOLUTION
My refrigerator are having the same problem. The model is RS263TDWP
Highlighted
JUMP TO SOLUTION
This link should help with this issue.
Highlighted
JUMP TO SOLUTION
We have the same problem. Bought our fridge in November 2015. Model No. RF28HDEDPWW.
Highlighted
JUMP TO SOLUTION
Ours too , replaced ice maker last year , now the fan started top middle . Loud until we open doors . No help??
Highlighted
JUMP TO SOLUTION
My RF28HMEDBSR is doing the same thing. I have ice build-up in the back wall between the outer plastic and the styrofoam insulation. How do you fix this? Why does this happen?
Highlighted
JUMP TO SOLUTION
I am having the same problem. Looks like numerous people are also experience but there’s no solution offered by Samsung on this thread. Samsung, help us out here.
Highlighted
JUMP TO SOLUTION
I have the same issue, I have defrosted monthly, replaced the ice machine, have had techs out multiple times! The fan makes noise, do not buy Samsung fridges.
Recommend putting silicone cone around the ice machine inside and out to seal it better. This worked for awhile but after 6 months it started again, at least I had 6 months without a noisy fan.
Try pulling the fridge out further from the wall as well.
Highlighted
JUMP TO SOLUTION
I have a mode RF22KREDBSG and mine is doing the same thing only there is no ice build up and my entire freezer is thawing....
Highlighted
JUMP TO SOLUTION
For assistance with this concern, please send us a private message to the link below.
http://bit.ly/2hQXHNu
