Flex duo oven top door problem
(Topic created: 05-13-2021 08:20 AM)
userQWiF57vh6f
Kitchen and Family Hub
The right hundreds popped out how do I fix it??
userQWiF57vh6f
I fixed it... thanks
SamsungJam
We would be more than happy to look into this.  Could you provide an image of the trouble as well as the model of your flex duo?
userQWiF57vh6f
SamsungJam
Fantastic! Don't hesitate to reach out to us in the future if you need us.
