- Mute
- Email to a Friend
01-15-2022 11:55 AM in
Kitchen and Family HubPurchased on 11/14/21, used the oven last night and this morning the display does not work. Frustrating being 2 months out of warranty and this completely stops working. The cooktop still functions but can't do anything with the oven because it can only be controlled by the touchscreen/display. I have removed power multiple times trying to reset the controls but nothing works in the oven, not even the interior lamp will come on when I open the door .
Solved! Go to Solution.
- Mute
- Email to a Friend
01-15-2022 04:16 PM in
Kitchen and Family HubHello, I apologize for the display issue reported and would recommend having the unit serviced by a technician especially if power cycling the unit has not resolved this matter. You can use this link https://www.samsung.com/us/support/service/ to find a service center in your area or private message me at https://bit.ly/3p4UuiW with your full model and serial number to review service options
- Mute
- Email to a Friend
- Mute
- Email to a Friend
02-23-2022 07:55 AM in
Kitchen and Family HubUPDATE:
Can't use the stove top any longer due to it being a fire hazard now. It's been over a month and a half and we can even get parts for this thing. Samsung couldn't even get us any help and just closed the service case. This is truly unbelievable, I have multiple Samsung appliances and will never purchase another one after this experience.
