Freezer Temperature Blinking
(Topic created on: 1/7/21 8:15 AM)
user3dDWCL9t1M
Kitchen and Family Hub
Whatever temperature is set on my freezer, that temperature is blinking on my fridge? Currently -4 is blinking as -4 is set as my freezer temperature. Also, freezer is not working at all. Any fix suggestions?
SamsungJam
Have you tried flipping the breaker to reset the fridge?  If the option is available, have you tried enabling power freeze?
user3dDWCL9t1M
No I have not. Will try both options if available and keep you posted.
SamsungTam
Thank you! Please do and have a wonderful day! :)
