Highlighted
Freezer is cycling cold to not working but fridge is fine
Hi
I have a Samsung Twin Cooling fridge (RFG297ACRS) and have been having a continuous issue for the past 3 weeks.
The freezer cycles from being freezing to not working.  Fridge is working fine and has been the entire time.
Technician says it's the compressor but I can't understand why if it's the compressor that the freezer still cools to well below freezing and then cycles back?
3 REPLIES 3
Highlighted
Re: Freezer is cycling cold to not working but fridge is fine
Can I have your ticket number for your repair via private message?
Highlighted
i don't have a ticket number.  i have a local repair shop that is certified by samsung working on the problem
Highlighted
Please send your full model code and serial number via private message.
