userFHbDjV7afr
Freezer will not open
JUMP TO SOLUTION
I have a Samsung model number RF323TEDBSR and cannot get the freezer to open. I pull it and it stops. Nothing is blocking it from opening nor is it frozen as I have unplugged the refrigerator and still can't get it to open.
1 SOLUTION
userFHbDjV7afr
Re: Freezer will not open
JUMP TO SOLUTION
Hi I watched a Youtube video that advised to just tug as hard as I could and was able to get it to finally open.
3 REPLIES 3
Black Hole
JUMP TO SOLUTION
Hey, I would be happy to look into this for you. Please send us a private message to http://bit.ly/2CGMMUe with your phone number as well as the model number and the serial number of the unit.
userFHbDjV7afr
JUMP TO SOLUTION
JUMP TO SOLUTION
Glad to hear you got it open, it's possible the seals had just sealed up super tight. Let us know if it continues to give you problems. Smiley Happy
