Highlighted
French 4 Door Fridge
JUMP TO SOLUTION
How do I remove the glass in the shelf above the crisper drawers?
1 SOLUTION
Highlighted
Re: French 4 Door Fridge
JUMP TO SOLUTION
The water filter does not need to be removed. The following snip is from the service guide, showing the button location in the center of the shelf, above the filter housing.
11 REPLIES 11
Highlighted
JUMP TO SOLUTION
Hey, give this link a shot.
Highlighted
JUMP TO SOLUTION
Thanks ... already saw and read that item.  It explains removing the drawers (which helped), but not the shelf or glass insert above.
Highlighted
JUMP TO SOLUTION
Remove the Vegetable drawer by pulling the roller part up. While pressing the button on the left of the shelf, lift the shelf up. Then pull the shelf straight out.
Highlighted
JUMP TO SOLUTION
Thanks for trying to help ... there's no button that I can find.  Here's a photo
Have already had the drawers out ... just took this pic with the drawer in, but sure can't find a button ...
Highlighted
JUMP TO SOLUTION
Unfortunately, this glass cannot be removed, just the shelf.
Highlighted
JUMP TO SOLUTION
Thanks ... I was afraid of that.  However, I would still like to get the shelf out and I haven't been able to figure out how to do it.
Any help you could provide would be appreciated!!
Highlighted
JUMP TO SOLUTION
You should be able to remove the drawers first and then lift the shelf up and out.
Please provide the full model code of the refrigerator.
Highlighted
JUMP TO SOLUTION
Here's a pic of the Model/SN.
The shelf lifts up a little but will not pull out.  Must the water filter be removed first?  Thanks!Fridge SN.jpg
Highlighted
JUMP TO SOLUTION
