French Door Fridge Ice Build Up
(Topic created: 09-07-2021 01:28 PM)
userXwiI90nfwr
Kitchen and Family Hub
I bought a package of samsung appliances in 2015.   The Fridge (RF28HMEDBSR/AA) started making fan noise: then stopped.   Our milk then starting going off.   I removed the back panel in the fridge and it was a solid block of ice.   I managed to remove all of the ice and moved the sensor as per some videos.   It still is getting ice.
I think the repair kit is DA82-01415A?
I never actually hooked up the ice maker, but i am now concerned that it is defective after reading this forum.
And as a bonus, all of the right side doors, and one of the left sides doors all broke at about the same time about 2 months ago.   We never overloaded them.   They are very expensive to repair.   Especially considering that I may have to give up on this fridge.
1 Reply
SamsungCaleb
I understand how this may be frustrating and want to help have you tried the troubleshooting in the accepted solution below?
https://us.community.samsung.com/t5/Kitchen-and-Family-Hub/Ice-Maker-Keeps-Freezing/td-p/1406007
