usergLe48Ouqlr
Fridge NOT COOLING
is anyone else in the Commonwealth of Virginia having ISSUES getting their fridge's fixed?
Why was my other order cancelled?  order #4XXXXXXXXX?  my fridge is still not cooling and it STILL has the SAME LEAK From 2 years ago that NO ONE HAS REPAIRED!!
i understand that it is out of warrenty; however, back last June AND last October i was told that the part would be ordered, that it was a KNOWN ISSUE, and that i would only be charged for the call, not the part.  and now, my service ticket was CANCELLED???
2 REPLIES 2
Re: Fridge NOT COOLING
Please send us a private message with any ticket numbers that you have: Link
userw9fcFRPvJ7
FIXED:
-Unplug your refrigerator
-Remove rear bottom panel and vacuum out all the dust in the coils
-Open doors and remove all food and shelves (might as well clean the now)
-Remove twin cooling panel by removing screws
-Take a hair dryer to all the ice (put towel under the condensor)
-Wrap copper lines in paper towels, then wrap the paper towels with aluminum foil to make homemade insulation over the pipes in the upper right corner
-Reinstall everything
-Plug back in
-Made sure the fridge is at least 2" from wall
-Hold down the Power Freeze and the Power Cool buttons at the same time for 3 to 5 secs to take it out of showroom mode where the cooling is not set to operate
-Everything will blink then it will stop. This resets the fridge
-You're welcome
@userwzl3eIwFGp  @userRlWFVIvJFk @SamsungLou @usergLe48Ouqlr
