Gas Slide In Range Error Code E-83
(Topic created: 06-20-2024 01:08 PM)
PgM1
Kitchen and Family Hub
Gas Slide in range NX58K9500WG getting E-83 error code.  Not finding much on this code.  Advised to replace control board  DE-96-01050A.  Did so, and no fix.  In fact, created new malfunctions like mismatched key results on front panel.  At a loss, of how to proceed.  Local technician simply googled the error code.  I've done that without a lot of success.
1 Reply
GaryB82
Epic Samsung Care Ambassador
I would suggest contacting support and have a tech check it out to see what the issue is
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
