Gas range center burner/griddle does not adjust flame
(Topic created: 05-05-2021 04:51 PM)
Karen l
Kitchen and Family Hub
Hello Everyone,
I recently bought a new range and the center burner doesn't adjust flame, even though knob says hi, medium and low. I had repairman come and he said that the center burner is only for warming. Is this accurate?
Thanks
Not applicable
The oval center burner has a lower BTU rating than all but the small back burner, disbursed over a larger area. The adjustment level will be much smaller visually than the round burners. Check the User Guide pages 27 - 29 for information on using the burnet. If the performance does not match what you expect, we can have another tech check it out for you.
Not applicable
Could you please provide the model number for the range?
Karen l
Model NX58R5601SG
Not applicable
