Cosmic Ray
How To Best Clean A Cooktop?
JUMP TO SOLUTION
I recently purchased a Samsung Electric Range, Model: NE59R4321SS. All ready the cooktop looks like a bad tint on an auto window. I have been using a liquid dishwashing detergent. Any suggestions?
1 SOLUTION
Re: How To Best Clean A Cooktop?
JUMP TO SOLUTION
Below is a link with information on how to clean and take care of your cooktop:
https://www.samsung.com/us/support/answer/ANS00060833/
1 REPLY 1
JUMP TO SOLUTION
