Highlighted
How to get refrigerator rf265beaesr/aa out of retail mode?
JUMP TO SOLUTION
How do I get it out of retail mode? Can’t even acces the settings tab. Need a password of some sort. Any help would be appreciated
1 SOLUTION
Highlighted
Re: How to get refrigerator rf265beaesr/aa out of retail mode?
JUMP TO SOLUTION
Was able to figure it out. Help button 2(one with 3 lines) which brought me to a screen where I could factory reset from there!
6 REPLIES 6
Highlighted
Scan ur arc code inside and it will allow you to chat dir...
JUMP TO SOLUTION
Scan ur arc code inside and it will allow you to chat directly. Same issue happened to me.
Highlighted
Re: Scan ur arc code inside and it will allow you to chat dir...
JUMP TO SOLUTION
How would I happen to do that?
Highlighted
JUMP TO SOLUTION
Are you seeing "OF OF" on the display?
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
We're glad that you're up and running!
Highlighted
JUMP TO SOLUTION
How did you do this? I go into "settings" and the same password request comes up-- and I can't get into the "settings" area to do anything...
