Highlighted
ICE MAKER DOOR KEEPS OPENING and CLOSING CAN'T USE WATER!
My ice maker door keeps opening and closing nonstop. Can not get water or ice right now and it is 90 outside. This just started. Purchased less than a year ago. Does anyone know how to get help to get this fixed!
1 REPLY 1
Highlighted
Re: ICE MAKER DOOR KEEPS OPENING and CLOSING CAN'T USE WATER!
Have you attempted to turn the circuit breaker off for a few minutes to let the fridge reset and is the fridge plugged into the wall outlet all the way?
