Ice Bucket Replacement
(Topic created: a week ago)
Bobbiejo2261
Kitchen and Family Hub
Looking for Ice Bucket replacement for model #DA97-15217D
DA97-15217D refers to the entire ice maker assembly, which includes the ice maker unit itself, the motor, and often the ice bucket (or bin). If you only need the ice bucket (bin) and not the entire assembly.
Samsung ice buckets, you could investigate the following:
DA97-14474C
DA97-14474A
DA97-12604D
DA97-21040A
DA63-03507B
Be mindful of Long" vs. "Short" Ice Makers, but you should reach out to Samsung Support they will assist you with the correct replacement (bin) for your model #DA97-15217D.
Samsung Parts USA is the official Samsung parts website. While one listing indicated it was temporarily unavailable with a comparable part suggested, it's worth checking for the most up-to-date information.
Samsung_Moderator
Hey @Bobbiejo2261! Thank you for reaching out!  The information from @angelunchained was correct. To make the process a little easier, I would suggest reaching out to our parts distributor at 800-627-4365.  They'll be able to get you specifics for your ice maker, and they'll make sure you're good to go.
Thank you for being a Samsung customer.
