Ice Dispenser flap does not open to let ice drop
(Topic created: 09-20-2021 05:10 PM)
uservr1w9lsaEw
Kitchen and Family Hub
Hi,
I have a Samsung 48" Side by Side Built In Refrigerator   Model # RS27FDBTNSR   26.5 cu ft  w/ 8" Touch Screen.    Bought it in March 2016 and have loved it.
The problem is the flap does not open to let ice drop.   When you push a cup to dispense ice, you can hear the ice drop but can't get past that flap.    Open the freezer door and the ice is sitting in the **bleep** being held in by the flap.   So I can tell the flap is not just opening on weight of the ice.
Ideas on whether this is a mechanical issue or an electronic control issue?
Also is there a Samsung approved repair company in vicinity of zip code 75032?
thanks,
Douglas Jones
1 Reply
SamsungLou
I understand this is frustrating. The dispenser issue could be either mechanical or electrical, and determining the exact cause will require a technician to look at the unit. I am including information for the two service centers in your area.
PREMIER APPLIANCE SERVICE
308 Industrial Dr.
Forney, TX
469-230-4079
NISIUSA INC
1345 Valwood Pkwy. Ste.304
Carrollton, TX
1-972-488-0001
