Highlighted
Ice Maker Isn’t Making Ice - RFG297HDRS
Hello,
My ice maker isn't making ice. I've tried pushing the reset button, and no chime happens (despite holding it down for up to 15 seconds). Water is still able to be dispensed. I don't see any ice buildup. The "ice off" isn't selected.
any suggestions?
thank you!
6 REPLIES 6
Highlighted
Re: Ice Maker Isn’t Making Ice - RFG297HDRS
How long have you had this unit?
When was the last time you changed your water filter?
Is the unit leveled? (see link below)
https://www.samsung.com/us/support/answer/ANS00062321/
Highlighted
Hello,
Thanks for your response. We have had this unit for approximately 6 years. Filter was changed last month, and it is level.
Highlighted
Thank you for confirming. When dispensing water, how many ounces of water are you able to dispense in 10 seconds?
Highlighted
Hello,
It dispensed 10.3 ounces in 10 seconds.
thank you!
Highlighted
I would like to look further into this for you. Could you provide the serial number of the fridge via private message?
Highlighted
Thank you, private message sent.
