user4W9neDIUf3
Ice Maker Issue on Model RF263BEAEBC/AA makes ice after reset then beeps and stops making ice
JUMP TO SOLUTION
I hope someone has had this issue and knows a resoluion
Ice Maker not makingice
I reset the ice maker
The ice will dispense - I can hear it go though one cycle.
Then there's a beep
Ice makerstops working
No visible blockages.
Thanks for any help!
1 SOLUTION
user4W9neDIUf3
Re: Ice Maker Issue on Model RF263BEAEBC/AA makes ice after reset then beeps and stops making ice
JUMP TO SOLUTION
In case this helps anyone - the solution was replacing the ice maker.  Very simple to do.
10 REPLIES 10
user4W9neDIUf3
JUMP TO SOLUTION
Anyone?
JUMP TO SOLUTION
If ice only drops from the ice maker if the test/reset button on the ice maker is pressed, verify that the Ice Off icon is not illuminated on the display panel. When Ice Off is enabled, the ice maker is turned off. However, when pressing the test button, the ice maker will harvest any ice that is in its ice tray.
To verify that the control panel is working properly, enable and then disable the Ice Off function. On rare occasions, Ice Off may be enabled but the display indicator no longer functions correctly. In this case, service is required.
user4W9neDIUf3
JUMP TO SOLUTION
Ice On/Off appears to be working.  If resetting only "harvests" one batch of ice - then stops - is this an indicator that the ice maker needs to be replaced?
Honored Contributor
JUMP TO SOLUTION
Possibly, if you've done the steps above this article has the next steps: http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=669261&modelname=&mo...
If none of this helps, then yeah service repairs is what the next recommended step would be.
user4W9neDIUf3
JUMP TO SOLUTION
user1hwPyDlE4v
JUMP TO SOLUTION
I had this issue. The little pipe that pours water into the tray was frozen. I didn't know this, but I blew a hair dryer at the ice maker for 5 minutes. I used the test button and it shot a little chunk of ice out. I tested it again and I could hear it filling.
Hope this helps someone.
userMjPusa24ys
JUMP TO SOLUTION
This doesn't make much sense... if the pipe was frozen, then the reset button should not have resulted in one batch of ice...
userPI0tsM6JvQ
JUMP TO SOLUTION
Hi, any update how you solved this issue with stop making ice after one cycle and a chime?
mine just did the exact same things
thanks
userPI0tsM6JvQ
JUMP TO SOLUTION
did you end up replacing any parts?
