10-24-2019 10:14 AM
Yes same thing with me
08-02-2020
02:25 PM
• last updated
a month ago
by
SamsungBri
yes, I have the same issue with my Samsung fridge and the ice maker. I can't find anything about a fix for this.
08-22-2020
04:41 PM
• last updated
a month ago
by
SamsungBri
I am having the same problem with mine. I defrost the ice maker and less than a week later it is frozen over again. This is ridiculous.
09-25-2020
01:43 PM
• last updated
a month ago
by
SamsungBri
Mine is doing the same (at least monthly) and now the fast defrost function no longer works. Cost is over $600 to fix so will just buy a portable ice maker. This is a problem Samsung has been aware of for years - as evidenced by the class action suit on this issue. Time to invest in a much cheaper portable ice maker for a solution. Everything else on the fridge works. When it needs replacement, it won't be a Samsung. They make great TVs and phones but their refrigerators are horrible.
11-07-2019 10:29 AM
I just wanted to post an update and say that Samsung came out within days of this post and fixed my ice maker. I had zero expectations when I posted this - hoped maybe someone would have some magical advice but never imagined Samsung would respond and come out and fix the issue. I'm a happy customer and incredibly thankful. Thank you!
11-11-2019 04:19 PM
What did they do to fix?
12-25-2019 03:56 PM
In or out of warranty? Thanks.
04-06-2020 10:48 AM
It will happen again, they did the same thing with ours.
11-07-2019 06:06 PM - edited 11-07-2019 06:08 PM
I, too, have a Family Hub fridge that has the ice maker freezing problem. The ice maker was replaced approx. 1 year ago and all gaps sealed with silicone. The only improvement has been the unit no longer leaks water into the fridge compartment. I have to use a hair dryer on the ice maker about once every two months, or less. I don't remember reading in the owner's manual about needing to thaw the ice maker with a hair dryer!
