User_RsrkMHB
Re: Ice Maker Keeps Freezing
JUMP TO SOLUTION
Icemaker is "freezing"...hahaha😂
MDGuy
JUMP TO SOLUTION
I had the same problem, Samsung came out within days and fixed it. Replaced a circuit board, new firmware. I believe. Totally free/covered by warranty. Worked flawless since.
userbmrn2MsSiZ
Ice Maker Freezing Up
JUMP TO SOLUTION
Like so many people before me the ice maker constantly freezes up. When you remove the ice maker bin there is what appears to be ice cubes frozen between the top of the ice maker and the wall of the unit where the bin slides in. No matter how many times you clear them out, it happens again within a matter of a two weeks. Yes, the fridge is level and the temperatures are: freezer 0 fridge 35.
userEq5EnJqlrp
The same thing keeps happening to me...Clearing lines and...
JUMP TO SOLUTION
The same thing keeps happening to me...Clearing lines and emptying trays evennchanging temps.Annoying to say the Least
Samsung_OPpDZUZ
I do alot of those Samsung ice makers. They usuallare fro...
JUMP TO SOLUTION
I do alot of those Samsung ice makers. They usuallare from 6months out to 6 years old. It will have to be done by a good qualified technician. The cost will range from 350 to 700 depending on model. It will need an icemaker, y clip asm, glue, and some models will also need a control board and augers motor assembly. I can do them without the control board and augers. The problem is that the ice room isn't sealed properly and the original icemaker is wrong. I've honestly done over 100 of them without having any call backs.
userbmrn2MsSiZ
Re: I do alot of those Samsung ice makers. They usuallare fro...
JUMP TO SOLUTION
I paid extra to have the manufacturer's warranty extended for 5 years(BestBuy) so it sounds like my best bet is to call them and have the icemaker replaced as the fridge is only 3 years old.
jennluau
JUMP TO SOLUTION
I have been having he same issues with my ice maker.  Where are you located? Can you fix my Samsung? Or know where I can find a repairman who actually knows how to correct the issue?
userrEVVijczE2
JUMP TO SOLUTION
where are you located ?
userYRz4EGG1ta
JUMP TO SOLUTION
What do you mean the ice room isn't sealed properly? Defective?
Samsung_OPpDZUZ
Also under NO CIRCUMSTANCES. DO NOT USE A BLOW DRYER. Use...
JUMP TO SOLUTION
Also under NO CIRCUMSTANCES. DO NOT USE A BLOW DRYER. Use a steamer to defrost it. If u melt or warp the plastic. You will ruin the refrigerator.
