Highlighted
Re: Ice maker is frosted over
JUMP TO SOLUTION
What's the model of your fridge?  That way we can get you the proper instructions.
Highlighted
JUMP TO SOLUTION
I have a RF23J9011SR.  Can you please post instuctions on how to reset the ice maker?
Highlighted
Honored Contributor
JUMP TO SOLUTION
userprt8cnLU0u -  You can find steps for this in this article for your model: http://www.samsung.com/us/support/troubleshooting/TSG01001012/
Highlighted
JUMP TO SOLUTION
What if you can’t get draw out because ice build up is so bad
Highlighted
JUMP TO SOLUTION
Turn of ice maker. Here is how
https://www.youtube.com/watch?v=4V7QKqtBLeY
Samsung 4 door refrigerators often freeze up so you cannot get ice or even empty the ice bucket. Here is a simple free fix.
Highlighted
JUMP TO SOLUTION
Samsung should make a smaller ice maker assembly do the ice can fall.
Highlighted
JUMP TO SOLUTION
I had the same issue, I was able to pull it open enough and aimed the hair dryer at the crack, eventually it popped open all the way. Make sure to put down some towels.
Highlighted
JUMP TO SOLUTION
Mine is doing the same thing.  2 months old.  Chatted on-line to Samsung last night.  3 different links.  Still do not know why it  is happening after only 2 months.  Sounds like a fault of the design.
I have to defrost and reset; I will try this when I have some time this week-end.  If it happens again, calling for a tech out for warranty
Highlighted
JUMP TO SOLUTION
Please keep us posted if you need us to set that up.
Highlighted
JUMP TO SOLUTION
I had contacted Samsung support, which were of no help whatsoever.  They suggested resetting the ice maker.  I tried it and it did not work, which is why I had turned to this forum.
I did not want to defrost the entire fridge/freezer.  At first, I tried putting narrow containers of boiling water in the ice maker, but it did not work.  So, I pulled out the hairdryer.  It worked great.  Be ready with some towels though.  It melts fast.
To do this, pull out the bottom drawer before starting and put a large towel on the (inside) bottom of the fridge.  Put a small towel in the bottom of the ice maker.  Then begin with the hairdryer.  It doesn't take long, but be sure to melt the ice behind the ice maker (inside).  Once you start melting the ice, you can feel it in the back of the unit.  It gets pretty hot in the ice maker pretty fast.
Once defrosted and dry, reset the ice maker and re-insert the tray.  Samsung has a great diagram on how to reset the ice maker.  I cannot find the link, but it has very helpful pictures on how to reset it.  Maybe the Samsung Moderator could post the link in a reply.
That did the trick - until next time.  We are making ice again.  I just now opened up the ice maker - and I am happy to report that I don't see any frost building up - and a full tray of ice.  Hopefully, the problem is solved.  Good luck.
