userf3BJH1gYhB
Ice maker does not work - RF263BEAESR
JUMP TO SOLUTION
Clearly I’m not the only one who had this problem. My ice maker worked just fine till right past the warranty period. Then it stopped working, started back on its own, stoped again. I reset it and it works. Now completely doesn’t work ever. Also has leaked out the bottom for a couple years now. I’m very interested in joining in on the lawsuit that I hear about. Samsung are you going to do anything about this?
1 SOLUTION
Re: Ice maker does not work - RF263BEAESR
JUMP TO SOLUTION
If you have been over the various troubleshooting listed on the boards, then repairs would be our only other recommendation. We can make no guarantees, but in order to look into possible coverage can you send us a private message with the full model code and serial number here?
1 REPLY 1
JUMP TO SOLUTION
